How: an adaptive chord with midpoint always drop 2% of the chord length
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
heichan88
262 Aufrufe, 4 Antworten
I need an adaptive  chord cable with its midpoints always drop down 5% of the cable length,
but tried many ways but unable to do that,
Please advice, thanks
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: heichan88
You don't drop the midpoint, but host another point on that midpoint and offset from host a distance equal 2% of the chord length.
Nachricht 3 von 5
heichan88
als Antwort auf: ToanDN
Hello ToanDN
now I :
setp (1) make a point B offset L/2 to start point adaptive A
step (2) make a point C offset L*0.05 to B
step (3) add adapitvc end point D with a reporting parameter L to A,
seems work --- is that correct? any other way?
Please advice thanks
Nachricht 4 von 5
Try this family.  It was done exactly how I described earlier. I repeat the steps here:
- place 2 points, make then adaptive
- create a ref line thru the 2 points above
- place a dim between 2 points, associate the dim with a reporting instance parameter [L]
- place a ref point in the middle of the ref line, no need to add dimension or constrain, it stays in the middle of the ref line automatically (beauty of adaptive family)
- place another ref point using the midpoint as host, select the new point and change Offset from host to a arbitrary value from properties
- associate Offset from host with another instance parameter [h], enter = -(L/50) in the formula box of [h]
Nachricht 5 von 5
heichan88
OK that is much better, thanks
