SO SICK OF COLUMNS NOT ATTACHING!!
Base12
Base12
How, still, years and years later in 2024 does this STILL NOT WORK?
[ The subject line of this post has been edited for clarity by @handjonathan Original: SO F'ING SICK OF COLUMNS NOT ATTACHING!!]
ennujozlagam
share this portion in a file so we can check?
Are you by chance trying to attach a nested column within a column family?
Base12
They're just basic, out of the box columns and beams.  Not nested or anything.  It does it to me all the time and regardless of the type of column/beam whenever I try to adjust either column or a beam within proximity of another one they go bonkers and will not behave.  Is there anyway to have "Disallow Join" be the default condition *before* beginning to draw a beam, etc? so that I don't have to dick around with manually disallowing every end of every beam from joining?  I get so frustrated with this stupid software being so fiddly to just do basic stuff.
SteveKStafford
Given your attached image, mind describing what steps you took/take to create them? Columns first, beams from column to column? Beam first then columns? Model in 3D view or plan view(s)?
Steve Stafford
