Can't upgrade file from Revit 2021 to Revit 2024 or 2025
11 ANTWORTEN 11
Nachricht 1 von 12
aaron.c37XVW
1289 Aufrufe, 11 Antworten
When trying to upgrade a file from Revit 2021 to either Revit 2024 or Revit 2025, it gets stuck at around 76% and never progresses any further. No pop-ups about families that can't upgrade etc, it just gets stuck at 76% and sits there all day with no error messages.
We have updated every other project to Revit 2025 in our office with no issues, just this one file that won't seem to upgrade.
We have already tried: Completely uninstalling all revit versions and re-installing. Tried upgrading the file on multiple different computers, still no luck.
I assume there must have been some sort of family or component in this file that is creating the conflict when upgrading.
Does anyone have suggestions on what else to try?
For the time being, we will just have to re-install Revit 2021 for anyone who needs to continue to work on this project.
In case it is relevant, this is a 3 Story single dwelling, with existing / demo and new phase modelling. Not a very complicated model. Mostly walls, floors, roofs and furniture components.
Beschriftungen (1)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: aaron.c37XVW
Try upgrading sequentially. 2021  to 2022, 2022 to 2023, 2023 to 2024, and then 2024 to 2025.
Nachricht 3 von 12
aaron.c37XVW
als Antwort auf: barthbradley
Thanks @barthbradley I'll give that a go and update if it works.
Nachricht 4 von 12
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Upgrading-a-...
Nachricht 5 von 12
aaron.c37XVW
Update: I have successfully upgraded the file to Revit 2024, sequentially upgrading to each version along the way. However the project still won't upgrade from Revit 2024 to Revit 2025 - It gets stuck at 72% with no error messages, just stuck processing / regenerating unfortunately.
Nachricht 6 von 12
SteveKStafford
How many warnings does the project have now that it has been upgraded to 2024 successfully?
Groups?
Design Options?
In-place families?
DWG imports/links?
Did you see any warnings during prior upgrades as you worked your way up to 2024?
Steve Stafford
Nachricht 7 von 12
aaron.c37XVW
It doesn't give any warnings at all when trying to upgrade to 2025, it's almost as if it doesn't get far enough through the upgrade to where the warnings usually pop-up.  There was a warning upgrading to 2024 and I think it was an in-place family warning.
Nachricht 8 von 12
SteveKStafford
How many warnings (Review Warnings) does the project have?
Groups?
Design Options?
In-place families?
DWG imports/links?
Steve Stafford
Nachricht 9 von 12
aaron.c37XVW
als Antwort auf: SteveKStafford
Sorry Steve, I didn't know that warning menu was a feature - See screenshot below - I can't see anything here that would be an issue - Should these ideally all be resolved?
Nachricht 10 von 12
SteveKStafford
Short answer, the higher the warning count the more likely it will impact your success. If you go to the last warning and expand that and scroll to the bottom you'll see how many total warnings there are. If you expand individual warnings you'll see how numerous they are for each. Less than 100 total shouldn't be too impactful, but >500 it's likely to have an impact and it indicates people are modeling with some bad habits.
  • The Attachment warning has been a problem for upgrading projects for me (and binding a project) in the past. It might also depends on how many there are. It is "easy" to resolve, just detach each of them since Revit isn't attaching to the thing it thinks it is supposed to attach to anyway.
  • I always encourage people to eliminate warnings that involve area/volume calculations so any wall overlapping walls, room separators overlapping each other or walls, floors overlapping,  etc.
  • Revit calculates area/volume continuously as you edit the model and interact with elements that affect area/volume. So it's possible that this is affecting the time/evaluation process required to upgrade.
  • Eliminate any rooms that are not placed or redundant.
  • Those that are not enclosed should have their boundary conditions repaired.
  • You have model issues with phasing of elements and there are numbers stair and railing complaints. The stair complaints are usually stair parameter values that don't match the number of risers created in edit sketch mode or the height constraints don't allow for the stair to be consistent with it's rules (riser count size/tread size).
You haven't answered regarding the number of groups, design options, in-place families, DWG imports/links yet. They can make it more difficult to process the upgrade. Also how many levels does your model have and how careful have people been to associate things to the correct level relationships?
Steve Stafford
Nachricht 11 von 12
aaron.c37XVW
Thanks Steve, I'll get rid of as many as I can!
We hardly scratch the surface of what Revit can do, all of our models are quite basic and don't rely on volume calculations etc.
I'll let you know if this fixes the issue :leicht_lächelndes_Gesicht:
Thanks again,
Nachricht 12 von 12
SteveKStafford
See my edited reply, I added some comments at the top and at the bottom.
Steve Stafford
