Snapping to objects in 3d views
I tried to add a toposurface to close the gap between an edge and a topography / floor / wall.
I cloud not find any way to do this , There is no way I know of to snap in 3d.
I don't know how you got a gap, but if I were to guess, I say you moved a split surface.  There is no way to close that gap. You'll drive yourself crazy trying.
But, you could try this: Export both surfaces to DWG and then Insert is back into Revit and create a Toposurface from the Import.
Let me know how it goes.  I got another one for you, if that don't work.
The gap is a result of having one topography with pads and another created from the rode plan.
What I did was to create a floor with  the correct levels and that has closed the gap.
Never the less I liked your suggestion and will try it just to see if it can help in other events.
Thank you,
David
