Slow performance issues while rendering in realistic mode
pan, zoom and other functions are super slow in Realistic with edges mode.  here is my computer :
I have Xeon CPU with 32 GB Ram and 256 GB of SSD storage, NVIDIA Quadro M2000 graphic card
any idea why is that ?
thanks.
dgorsman
Partially depends on the clock speed of your processor, but mostly on the graphics card and what you've got in the model.  The 2000-series Quadro cards are pretty low level.
Of course, if "The computer is slow when I do _____", then the somewhat-flippant answer is "Then don't do _____".  You're not going to get the same performance for higher-quality as you do for lower quality.
Viveka_CD
Hi @Anonymous
Sorry to hear about your slow down issues especially while rendering in in the realistic mode.
By default the realistic mode significantly slows down model navigation, especially in detailed models since this mode uses the render appearance asset defined in each material.
I recommend that you follow Best Practices: Render Performance and the Building Model. Click HERE for more information.
  • Hide unnecessary model elements
  • Change the detail level
  • Reduce the view area to render
Please see system requirements for the Revit product line HERE
Autodesk tests system hardware, graphics hardware and drivers. Check HERE for more information on graphics cards.
RECOMMENDED GRAPHICS SOLUTIONS FOR AUTODESK REVIT
Small models
Medium to large size models Very large models
  Quadro P400* Quadro P600* Quadro P1000*
  2 GB GDDR5 2 GB GDDR5 4 GB GDDR5
  Quadro K420 Quadro K620 Quadro K1200
  Quadro M620* Quadro M1200* Quadro M2200*
  2 GB GDDR5 4 GB GDDR5 4 GB GDDR5
  Quadro M600M Quadro M1000M Quadro M2000M
Click HERE for more information on NVIDIA recommendations.
Let us know if you were able to resolve your issue. Glad to help if you have any more questions!Smiley Happy
