Slopes in generic model by void
j-davelaar
Message 1 of 14
j-davelaar
This is my first post and I hope to find guidance here.
My company makes stackable units. These units their construction is a frame of structural columns and beams with a concrete floor in between.
One of the floors, which I need to create, has 2 sloped areas in it. I was planning to make these slopes with a box-shaped void, which I would rotate in 2 ways to make a slope. The highest point is -6mm and the lowest point is -30mm.
When I try to rotate my void, it says "can't keep elements joined" and then it doesn't cut my extrusion.
Any ideas on how to solve my problem?
Replies (13)
Message 2 of 14
martijn_pater
How about modify subelements? Possibly combining/joining multiple floors... edit: misread, you're using a generic model apparently, why not use regular floors?
Message 3 of 14
j-davelaar
Would be a great option, but unfortunately this doesn't work for my generic model
Message 4 of 14
martijn_pater
It's a one-directional slope? Not sure why you wouldn't be able to cut with the (in-place?) void... You could share the family/model to have a look perhaps...
Message 5 of 14
j-davelaar
Well the void must be tilted 2 ways (see image of wanted result), but 1 way already gives errors.
Hereby the file and how to slope it (back view). I place the rotational point at top left (see image) and I rotate it at the end of the void, 2 ref planes down.
Message 6 of 14
martijn_pater
Like the attached? *can't seem to add/upload as image.
Message 7 of 14
j-davelaar
That would be the best possible outcome, but this would also be fine(see image).
Just what is doable.
Message 8 of 14
martijn_pater
You could try building it as adaptive component family, not sure how you'd want to parametrize it though. It's a somewhat different approach I suppose. Otherwise you'd have to build it up from several joined solids, while making your section extrusion from different workplanes (not from section).
Or, maybe do build it in a project file using the modified subelements functionality you could parametrize that aswell using global parameters...
edit: hmm just thinking if I'm not overcomplicating it...
Message 9 of 14
j-davelaar
What is this for kind of family that you created?
Message 11 of 14
Welcome to the forum.
You know, there might be a better way to model this Revit/BIM Content.  You wouldn't by chance have any company/product literature on these stackable units that you could share with us?  Pictures, specs, what-not?
Message 12 of 14
j-davelaar
Thank you!
The choice of setting it up like this, shared nested parametric generic models, was a choice of the BIM consultant who is advising us.
Until this point it worked perfectly fine, but this problem is a minor problem.
I have added an image of the stacked units in Revit. This will be the structure family.
In the next year I will have to make a wall family (generic) and a roof family (generic). After that some small components like a radiator, toilet and airconditioning.
After that I will focus on adding information to the families which can help other people within the company do their job better or easier.
Message 13 of 14
martijn_pater
Hmm, well I think I would sooner do something like this with groups and/or (bound) linked model perhaps, not as a family although it is an option ofcourse. But much like recurring questions for how to do hotelrooms such as this one ie. or storage units I think like this topic...
Message 14 of 14
j-davelaar
@martijn_pater , I do understand the thought, but model grouping is more for interior design, isn't it? The most important about the units I make is that the modellers must have a list of default wall options, a list of default floor options and a list of default roof options, so they can quickly create the desired building of stacked units.
