Handrails
18 ANTWORTEN 18
GELÖST
Nachricht 1 von 19
stevenson953
2033 Aufrufe, 18 Antworten
Handrails
Hi Guys,
New to trying to modelling handrails and keen to get any advice before I take the plunge.
I usually model plants so know my way around REVIT a bit but not architectural things like handrails.
I would like to model this:
Any tips/links to a good tutorial etc would be gratefully received.
Paul
18 ANTWORTEN 18
Nachricht 2 von 19
martijn_pater
als Antwort auf: stevenson953
https://www.autodesk.com/autodesk-university/class/Designing-Custom-Railing-Panels-Revit-2017
https://www.autodesk.com/autodesk-university/class/Handrail-Hacks-2016
Those are some useful links/tutorials with regards to railings, although your example seems rather straightforward with ootb railing functionality. You could also find some examples using piping systems for railing structures actually, never seen tutorials for those though...
edit: Perhaps specify more clearly what you need to know, since the above is a rather generic answer...
Nachricht 3 von 19
syman2000
Here is a manufacturer railing you can use as sample. To edit the top railing, press tab and select the railing. Edit the railing and you can customized the end conditions to suit what you need
If you want remove middle picket, simple set the none.
Result is closer to what you want.
Nachricht 4 von 19
stevenson953
als Antwort auf: martijn_pater
Thanks and I'll go though those tutorials and see where that takes me.
Nachricht 5 von 19
stevenson953
als Antwort auf: syman2000
Thanks and I'll give them a go and again see how I go.
Nachricht 6 von 19
stevenson953
So I had a play with that railing and managed to do a few things as you will see below.
I'm struggling though to get it all in round, vertical rails removed with just a top rail and double bottom rail.  I also don't need any base plates.
Thoughts please? 
Paul
Nachricht 7 von 19
syman2000
That requires you to modify the baluster post family. Not sure if you are able to modify it yourself. I've attached sample so you can practice on your own.
Nachricht 8 von 19
stevenson953
Thanks but I can't change the
alignment of the posts or get
rid of the top brackets. I
can get the rails as required.
Maybe I should be looking at
simple tubes with welded
connections. I don't know how
to do that either.
##- Please type your reply
above this line -##
Nachricht 9 von 19
syman2000
If you want simple one, you can use the default Revit template and use 900mm rail. Duplicate it and you can adjust the placement. See attached
Nachricht 10 von 19
stevenson953
Thanks and that has helped me heaps.
Can this simple method also do rails at a slope for stairs and ramps?
Paul
Nachricht 11 von 19
martijn_pater
Edit sketch and set (parts of) sketchlines to slope in ribbon... or set sloped floor as host.
Nachricht 12 von 19
stevenson953
Thanks and I’ll give that a go.
Nachricht 13 von 19
stevenson953
I think I have cracked it!
I also found the following YouTube video of supporting help.
https://www.youtube.com/watch?v=YkNg6MC4S18
One last question, I haven't found out how to get the posts to be equal distance between end posts.  Any ideas  please?  That should wrap it up then.
Paul 
Nachricht 14 von 19
syman2000
If you want post to be equal distance, change the post to spread to fit and make sure you choose truncated pattern.
Nachricht 15 von 19
stevenson953
Thanks for all of this help, its really appreciated.
Equal Spacing done!
Just getting into some of the details now.  I have balustrades extending past the corner/end posts, a strange offset at the corners and I would like to introduce a gap with a smaller post just under the top balustrade.  See below.
Thanks again.
Cheers
Paul 
Nachricht 16 von 19
syman2000
Railing will break if you have uneven surface like topography. If you have simple slope like floor slab, you wouldn't run into that problem. As for baluster, you may want to create baluster family and replace it. I've attached sample you can learn how to create it.
Nachricht 17 von 19
stevenson953
Nice!
See attached.
I still have the weird setdown at the corners and I do believe that I have a simple floor and no topography.
I also have the rails sticking out a bit at the end/corner posts.
Do you have a solution/family for escutcheons to finish of at the floor please?
Nearly there.
Cheers
Paul
Nachricht 18 von 19
syman2000
Change it to simple and you should see smooth transition
Nachricht 19 von 19
stevenson953
Solved, we are done!
Thank you so much for all of your help.  Martin too!
Cheers
Paul
