Slanted wall with a cut out for Window
3 REPLIES 3
brianwclayton1969
188 Views, 3 Replies
Good evening Revit users,
I created a slanted wall, and behind the slanted wall is a window. I'm trying to cut an opening in the slanted wall. When I select the slanted wall I can't edit the profile, BUT when I change it back to vertical and create the opening THEN try to change it to slanted, I get a error warning stating "A wall with an edited profile must have a vertical cross section" What does that mean, please? It's probably something simple.
I have attached pics on the steps and the error.
Any and all assistance would be helpful.
Thanks Brian
3 REPLIES 3
in reply to: brianwclayton1969
You can cut a slanted wall with a window and choose the window to be slanted or vertical.
If you only need the opening then use an opening family (right one above).
Toan Nguyen
brianwclayton1969
in reply to: ToanDN
THANKS SO MUCH!!! The Window opening worked it was awesome!!
Just what I needed.
Brian
Forma Design Contest
Technology Administrators
