Sketch line to thick.
There is one common problem I face whenever I work in creating mass,generic models,creating curtain wall families and that is the sketch line is way to thick that it cause a lot of inconvenience.Also it's not only the sketch line but also the reference line that also have these problem.Is there a way to make reduce the thickness?
Thin lines ON?
Type in TL to toggle line thickness on and off at will.
Thanks for answering,that made things a lot easier.
You're welcome. Glad I could help you both.
