Can't to import .sat file
Hallo,
I've seen similar topics on the forum, but there aren't helpful methods saddenly..I've created a model in fusion 360, then used a dynamo to fix its geometry and then revit told me that "it should be converted to autocad and then open it again" or something similar... Anyway, it didn't open it! I've tried to convert the form to 3ds and dwg via autocad and 3ds max, but i need to cut this form into segments and after 3ds it's impossible... I don't know what to do and near to cry, collegues, you are my last hope!!!
cbcarch
Try importing it into a Family, name the Family and Load into your Project.
Make sure Imported Categories are on and "imports in families" is checked in Visibility/Graphics setting of your view.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
