Site Designer
Site Designer
Message 1 of 14
Site Designer
I cannot figure out how to get the Site Designer tab to show up on my ribbon. I have downloaded, uninstalled/reinstalled and downloaded the update and still no luck.
Replies (13)
Message 2 of 14
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
Which version of Revit do you have? Have you already checked and followed the suggested troubleshooting steps in this Autodesk Solution on Revit: Site Designer doesn't appear on ribbon after installation? Thanks.
Jeffrey Sin
Autodesk Customer Support
Message 3 of 14
Hi Jeffrey,
I am using 2018. And yes, I have already taken the step listed in the post you linked. I am out of ideas. I just downloaded a plugin (not Autodesk) yesterday and it worked fine. Not sure what I am doing wrong.
Message 4 of 14
jeffrey.sin
Hi @Anonymous,
Thanks for the confirmation. When you go to the folder C:\ProgramData\Autodesk\Revit\Addins\2018, is Site Designer Extension showing up there?
Jeffrey Sin
Message 5 of 14
No it is not... does that mean I didn't download it correctly?
Message 6 of 14
jeffrey.sin
If it's not showing up there, it could be that the extension was not properly downloaded and installed. I suggest that you go back to your Autodesk Account, either go to Product Updates or click on Revit, select Downloads, and go to Updates & Add-ons tab, then download Revit 2018 Site Designer from there once again and use that to install the extension.
Let us know how it goes.
Jeffrey Sin
Message 7 of 14
I went to download it again and it was already downloaded so I uninstalled it. Before I try to download it again, is there anything you suggest that I should do?
Message 8 of 14
jeffrey.sin
Nothing out of the ordinary I guess, here's the link to the instructions from the Revit Help Guide: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-EC521BB9-83BF-4245-91F4-18ED94D2A284
Jeffrey Sin
Message 9 of 14
OK, I noticed the add-in is in the 2017 program file but not the 2018 even after I downloaded the upgrade. Do you know why this might be happening?
Message 10 of 14
Downloading the update from the app located on my desktop fixed the problem.
Message 11 of 14
jeffrey.sin
Hi @Anonymous,
Apologies for not being able to get back to you sooner. That is awesome! I'm glad you were able to fix the problem you were facing and we appreciate you sharing your solution/workaround with us here.
Thank you.
Jeffrey Sin
Message 12 of 14
gccdesign
Ditto, used the "Autodesk Desktop App".
GChapp
Message 13 of 14
hi ! i have the same problem, i downloaded the zip you gived in link, but when i tried to install it, that not found, and the winrar closes !
Message 14 of 14
Thanks very much this worked like a charm.
