Site Designer Error
Site Designer Error
leslieFRT9A
Site Designer Error
leslieFRT9A
Revit 2020
Windows 10
I am trying to insert a road into a site I created in Massing and Site via the Stedesigner addon for Revit 2020.  I have created the copy topo surface using "Set Base Toposurface".  When I attempt to insert a road using either predrawn reference line or drawn line I get the message in a Windows 10 error box "Index was out of range.  Must be non-negative and less than the size of the collection.  Parameter name: index" Screenshot attached.
Can anyone advise on how to resolve this error.  I havent yet tried removing the site designer addon but that may be a fix although I suspect on reinstall it would pick up whatever data is causing the current problem?
Sure hope to hear from someone.
RDAOU
Hard to recreate the issue cause that prompt...Please upload to .rvt to check
PS: I wouldn't use site designer to create roads. I would use a railing element which can be hosted on the topo-surface.
