Site Designer Error
2 REPLIES 2
leslieFRT9A
630 Views, 2 Replies
Site Designer Error
Revit 2020
Windows 10
I am trying to insert a road into a site I created in Massing and Site via the Stedesigner addon for Revit 2020.  I have created the copy topo surface using "Set Base Toposurface".  When I attempt to insert a road using either predrawn reference line or drawn line I get the message in a Windows 10 error box "Index was out of range.  Must be non-negative and less than the size of the collection.  Parameter name: index" Screenshot attached.
Can anyone advise on how to resolve this error.  I havent yet tried removing the site designer addon but that may be a fix although I suspect on reinstall it would pick up whatever data is causing the current problem?
Sure hope to hear from someone.
2 REPLIES 2
RDAOU
in reply to: leslieFRT9A
Hard to recreate the issue cause that prompt...Please upload to .rvt to check
PS: I wouldn't use site designer to create roads. I would use a railing element which can be hosted on the topo-surface.
