Hi All,
I would like to find out if it's possible to edit the resulting contour lines that come after creating a pad with the Site Designer. Do see Attached.
I would like the resulting contour lines that appear to the side of the pad to be filleted without a radius. Is there any option to edit this ?
Solved by Viveka_CD. Go to Solution.
Hi @oladamilola
Please see the link HERE on how to use site designer to grade the toposurface, create building pads and modify the terrain. You can use uses host lines and specialized families to modify the toposurface.
Let me know if this resolves your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thanks for the link to the Video. But the Video doesnt help and neither does it closely brush the Question i asked.
Hi @oladamilola
Elements created using Site Designer sketched lines can be difficult to modify.
Can you try the following options for me?
Let me know if you were able to resolve your issue, while I look for more workarounds. Send us a model to test if possible.
Viveka CD
