How can I achieve this type of connection for walls? (It's simple brick wall)
Solved by RDAOU. Go to Solution.
First Option: easy way is to duplicate and rename the Brick Common Material for the 120mm walls of the shaft. This way when you join geometry with the other walls, the material will not merge and you keep that join line which you have there
Second Option is to model the 4x 120mm Brick walls as a Hollow column with a nested detail item or added symbolic lines for the linework ie: this way even when material join you would still have the cut line at that join)
Third Option is to use the tool Cut Profile (Ribbon >>> View >>> Cut Profile)
Forth Option is to convert to parts >> Divide Part >> Exclude
