Hi all, I have 2 questions.
1. I need some help in working out how I can write the formula so that the garage area displays the area minus 36m2. For example if the garage area was 45m2 then I want the schedule to display 9m2
2. How can I display a subtotal row after the ground floor and first floor living areas. Followed by the grand total including the garage area?
Thanks in advance 🙂
Solved by martijn_pater. Go to Solution.
See below. Edit schedule fields and add calculated field. edit: for second question you would also need to set formatting to set calculate totals for area/calculated area.(4)
