- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
New Revit user transitioning from Autocad where I;ve been comfortable for 30 years. Working in Autocad Architecture so 3D concepts are not new.
Is there a simple CHAMFER command to put a 50mm straight chamfer between 2 lines ??? Theres a FILLET > Radius and a TRIM> Corner but I can't seem to see or work our a simple 50mm chamfer between 2 lines without using the offset command, draw a new line and then do a trim on them ??? Am I missing the forest for the trees ????
