hi, its a curtain wall. what is the easy way to adjust the bottom mullion by 150mm fron finish floor. thanks you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
ok, but i need the vertical mullion remain in the same position, only horizontall mullion need to move, if i change the properties to 150mm everthing wll move. ? thanks
