Show same parameter value in two different parameters
philip_adrianLNKAM
philip_adrianLNKAM
Community Visitor
Community Visitor
Hi!
I want to be able to get a value from a third party add-in parameter directly into my own parameter if that is possible.
The add-in generates a parameter with the name "Brandmotståndsklass" but I want that same value in my own parameter named "Brandklass". Preferably without having to run a script for new objects or any manual typing, just want them showing the same value.
The parameters are both text parameters.
Philip
eklund.rickard
Hello
I think you need a dynamoscript in order to achive this. Could look like this:
Enter this in the formula box of Brandklass:
=Brandmotståndsklass
eklund.rickard
Can this be done i a wall?
So, what you are saying, is that a 3rd Party Add-on has added a Project Parameter (Text Type) with a particular value to ALL your System Family Wall Types and want to have this 3rd Party value automatically copied to a another Text Parameter Field that you have under the Wall Type Properties?
I would do this via a Schedule.  Be easy enough to do.  I mean, they're Type Parameters.  Changes to one affect all.
For system families, you will need the use Dynamo.
