I want to hide all wood framing in a job, show only steel framing. Unfortunately both are all the same category: " Structural Framing". Without manually selecting each member size and "select all instances in entire project" indivdually. See video here:
https://drive.google.com/file/d/1llkB0EAZ20ebG-Qb2E-zeoy7pUrJx1ps/view?usp=drivesdk
Thanks.
Solved by ToanDN. Go to Solution.
Solved by RDAOU. Go to Solution.
Either use Worksets
Or Use a View Filter (a rule based using a parameter)
You can apply filter to
You are welcome but you do not need to mark 2 solution...it is pretty much obvious it is a copy paste
