Show Only Steel Framing
6 REPLIES 6
steve
359 Views, 6 Replies
I want to hide all wood framing in a job, show only steel framing.  Unfortunately both are all the same category:  " Structural Framing".    Without manually selecting each member size and "select all instances in entire project" indivdually.  See video here:
https://drive.google.com/file/d/1llkB0EAZ20ebG-Qb2E-zeoy7pUrJx1ps/view?usp=drivesdk
Thanks.
6 REPLIES 6
RDAOU
in reply to: steve
@steve
Either use Worksets
Or Use a View Filter (a rule based using a parameter)
  • Either Type Name (if you want to apply to specific types)
  • Or use Family Name (if you want to apply to all the types of that family)
You can apply filter to
  1. hide certain types/families (ie: using Family or Type Name + Equal to)
  2. or to isolate certain ones (ie: using Family or Type Name + Not equal to)
in reply to: steve
Create a View Filter based on Structural Material: does not equal Steel
steve
in reply to: steve
steve
in reply to: RDAOU
Excellent animation, thanks for taking the time.
RDAOU
in reply to: steve
You are welcome but you do not need to mark 2 solution...it is pretty much obvious it is a copy paste
steve
in reply to: RDAOU
can you link me to the source for your animation,  so I can start and stop.  It is very informative.
