Show Hidden lines in section
Hi everyone.I want to see hidden lines of stair in section view like second picture.I know using of detail line is one of solution,but I want to use show
hidden line because there are several stair in this view
You could switch the View to Wireframe visual style, and use the Linework (LW) tool to change the profile of the treads and risers to Hidden Lines. When done, switch the View back to Hidden visual style.
constantin.stroescu
it's odd that you can do it automatically in 3d but not in section or elevation view, using :View >Show Hidden Lines:
Constantin Stroescu
loboarch
It is a known limitation of the stair element in Revit to support hidden lines in an elevation/section view. It is logged with development for possible future development.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I think they should solve it.It is very useful to show hidden lines of stair in section view automaticaly.because if we have several stair it is not possible to use detail line for each of them.
Perhaps you can add another section that only shows the treads and risers, make it transparent, and put on the same Sheet.
