Show Hidden Lines - Does not work in Drafting Views
Juan.Ruas
Message 1 of 12
Juan.Ruas
Does anyone know how to fix this issue? Basically Revit isn't showing the hidden lines (Using the Show Hidden Lines feature), but if I print to PDF the lines will show normally.
Thank you!
Replies (11)
Message 2 of 12
ennujozlagam
you can overrides the lines by annotate > detail lines > line styles > hidden lines. and see if helps. thanks
Message 3 of 12
Juan.Ruas
I avoid using only lines as it takes more time to change in case I have to change the detail, plus it doesn’t work with Detail Components.
I’m trying to find a way to fix this issue, rather than contouring it
Message 4 of 12
ennujozlagam
can you here part of it so we can check?thanks
Message 5 of 12
Can you see the hidden lines when you zoom in?
Message 7 of 12
Juan.Ruas
No I can’t. I can only see them on a PDF
Message 8 of 12
Odd. Can you post the file?
Message 9 of 12
Juan.Ruas
I will do. I remember having a similar issue in a different company, a friend had to contact Autodesk to find the answer (but he didn’t share it with me)
Message 10 of 12
Juan.Ruas
Please find attached Purged file. Revit 2021
Message 11 of 12
Message 12 of 12
Juan.Ruas
WHY? Sometimes Revit annoys me sooooo very much!
Thanks mate, I really appreciate your time. How did you know that was the issue?
