Good Morning,
Hoping someone might be able to help me. I am looking to purchase a laptop for around £1'000 which is capable of running revit 2021, for architectural purposes (small models - not doing much rendering etc.)
I have looked at the systems requirements on the autodesk website but elements such as the graphics card spec are confusing to me.
I have found the following laptop, which appears to meet the spec requirements:
Medion Deputy P10 Core i7-10750H 16GB 512GB SSD 15.6 Inch FHD GeForce RTX 2060 6GB Windows 10 Gaming Laptop
Can someone please let me know if this is capable of running revit for small models? If not can you please advise on one to buy?
Any thoughts/ help/ guidance will be very much appreciated.
Kind Regards
you can refer to these link and link and see if helps. thanks
probably increase your 16gb ram to 32gb.?
You can find the System Requirements recommended by Autodesk here https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
The laptop you mentioned is better than the recommended for entry-level configuration, so I would definetly go with this laptop for smal-medium size projects.
