I have a modeled downspout that is below a modeled wall sweep (parapet trim detail). In plan, the downspout will not show up b/c it is under the modeled wall sweep but I would like it to show as so the roof plans read better. The modeled wall sweeps are within a skin group created for the exterior part of the units. I cannot make the wall sweeps transparent in the template. Work set is on the right one. I'm lost. I don't want to just draw a detail and place it around the building.
Solved by Prvoime. Go to Solution.
Would Show hidden lines work?
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-0C893628-9560-4913-8A44-2E61DD3ACBC0
