Shorten all reference planes at once
j-davelaar
j-davelaar
Good day!
Is there a way to make all reference plane lines shorter at once?
Thanks in advance,
Joeri
syman2000
Create scopebox and then select all your grids and tie to the scopebox
Afterward it will shorten to the scopebox
martijn_pater
In addition to the above, when you 'tie' it to a scope box and immediately after set it to none, it will jump back to the scope box' edges. Which is also a method used for exact positioning of scope boxes, as you can then select both of those and snap to the reference plane ie.
