Furniture lines displaying over Wall lines
nathaniel.mcmahon
nathaniel.mcmahon
Have an issue when full height furniture shares a common edge with a wall. The View range cuts both wall and furniture. The furniture (no detail masks or lines) model is displayed over the wall line. Is there a way to change this? I've seen solutions to other scenarios which don't apply to me. I've attached a file for reference.
Caed9
What I recommend you, in this case, is to create a plan region with a cut plane above the height of the family.
The View range Cut plane on the plan region must not be equal or less than the height of the Cabinet.
Another Solution will be to edit the family and uncheck the visibility settings of the geometry on plan/RCP and add Detail lines. Do not use masking region if the Planview's view range has a cut plane that is intersecting the family, because you will have the same undesired outcome and it will require a plan region again (Double work).
I believe you can hide the Plan region outline for pdfs and printing.
I turn off the 3d solid in the family and add symbolic lines for plan presentation. 3d is kept to shown on elevations and 3d.
adrian.troendle
I would like also some solution for this problem (from Autodesk I hope). It is not efficient to rework every single furniture in order to keep the lines' hierarchy.
eero.ilvessalo
Indeed, Autodesk! Please solve this issue. It does not make any sense to display furniture or casework lines on wall lines. This is a problem in every single project that our company is working on.
RSomppi
Autodesk isn't here. Try the IDEAS forum.
