I have been seeing a problem in a couple of our projects now. We use the typical OTB revision schedule built into our title blocks and they seem to be working, mostly. However when have been seeing Sheets being labeled as Revised when there are no revision clouds on the sheets. More confusingly, it only appears in some sheets. One of the projects that was affected we haven't even had any revision on because it is still in process of development. In this one instance I was able to fix it by creating a new Revision 2, moving it to before Revision 1, and then deleting Revision 1. This removed all the revised status on all the incorrectly labeled sheets. This won't work on another project that we are experiencing this problem with, seeing as we actually have 3 revisions. This issue here is that sheets that do not have the revision on them are actually shown as being revised. Please help with any suggestions you might have.
Solved by ToanDN. Go to Solution.
Thank you so much. I had seen the table chart on other posts but didn't know how to access it. I had clean forgotten about being able to put a sheet on revision without having a Rev Cloud.
That did it!!
