Good morning,
I hope this finds all well!
I want to make my "Drawn by" a label, so that it will show in "Manage Project information and I can use it as a label instead of typing it into every sheet.
I know I have a lot more to learn about this, but if I could understand this, It might give me a start.
Thank you!
Solved by bill_gilliss. Go to Solution.
Solved by Yien_Chao. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
How I accomplish something like this:
1.
2.
3.
4.
Constantin Stroescu
What you seem to be looking for is a project parameter that will be applied automatically to all the sheets. See
Add Custom Fields to a Titleblock:
You will probably want to create your own shared parameters file as part of that process.
