sheet number out of order in cover sheet
ben_smithZFR74
Message 1 of 12
ben_smithZFR74
even when I changed the numbers completely they stay in those rows on the cover sheet, any ideas on how to fix this?
Replies (11)
Message 2 of 12
kostask_oionei
Is this a sheet list?
You have to sort the list.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Message 3 of 12
Message 4 of 12
ben_smithZFR74
it is already sorted and there is a A600 series, but those two sheets wont go in numerical order with the rest of the 600 sheets
Message 5 of 12
SteveKStafford
Share the dialog sorting settings so we can see what the logic is now. That doesn't look like it is sorting by the sheet number primarily.
Steve Stafford
Message 6 of 12
ben_smithZFR74
here
Message 7 of 12
SteveKStafford
The three parameters that drive the sorting don't include the sheet number so as far as Revit is concerned the sheet number is irrelevant. It is focused on three parameters you aren't showing in your original screen capture. Discipline Order is the first thing it is sorting by, then Discipline and finally Sequence No. Work out if the correct information is entered for those A6xx sheets so they fall in the correct place in the list.
Steve Stafford
Message 8 of 12
@ben_smithZFR74 wrote:
here
Obviously your schedule doesn't sort by Sheet Number.
Message 9 of 12
ben_smithZFR74
obviously i just had to change the sequence number in the sheet properties.
Message 10 of 12
No.  If you want to sort by Sheet Number then add Sheet Number to the sort list, not Sequence Number.
Message 11 of 12
ben_smithZFR74
no, thats why it was out of order the seq no. was listed in the 200's not the 600's in the shet properties now its fixed.
Message 12 of 12
Why do you need Sequence Number when you can simply sort by Sheet Number?  Sequence Number is only needed if you DO NOT want to sort by Sheet Number, i.e.  A200 -> A600 -> A300.
