Sheet list
Sheet list
Sheet list
I made a sheet list with two columns....  drawing numbers and drawing titles!!!
Is there a way to add column for sheet paper format (for example A3, A2, etc.)?
And, is there a way to add sheet scale in another column?
Regards!
Corsten.Au
Hi
you can add any parameters available in Sheets.
if there are custom parameter ( text , number etc ) is required then you have few options
1. Add “ comment “ “ description “ parameter from sheet and manually add info like A3, A2 and scale etc
2. You can add “ Project Parameter “ Project parameter can be added to particular entities like sheet, views etc ... ex: Sheet size ( use text for this ) and add that “ sheet size “ in Sheet schedule..
find how to add “ Project parameter “ and that will help you do many custom additions..
3. Scale is a tricky parameter, it’s easy to have one scale for view.. but for Sheet , because Sheet can have multiple views with varying scale, it’s not a good idea to lock it to one particular view.. but you can also have a custome Paramter ( text , using comment, or project parameter) and write what you need to.
cheers
Corsten
Building Designer
@Corsten.Au
Thank you,
can you show an example for "sheet size"? (Print screen)
Regards!
Corsten.Au
Hi
In the Project Parameter, Add a new Parameter.
Name of the parameter
select Sheets
This should be an Instance Parameter. This allows individual Sheet to have unique text.
Choose Text - This will allow you to type Text without any constraints..
am uploading Screencast ( Video ) as well to explain how to add that parameter..and here's the screenshot
for final Sheet Schedule..
Link for the Screencast
https://autode.sk/2HaYbgR
Custom Project Parameter to show sheet size ( Text )Custom Project Parameter to show sheet size ( Text )
Corsten
Building Designer
@Corsten.Au
Thank you!
...thought at least sheet size would be automatic but this will be ok too....
Regards!
