sheet label
sheet label
sheet label
 how can I add a custom label in Revit Sheets?
To add a custom label in Revit sheets, open a dialog box Go to the home tab, select label in the text panel Click the place where you want to place the label. This will open a dialog box Select add new parameter Another dialog box opened, click select Select your shared parameters and then click OK Click OK again until you see the edit label the only dialog box opened Repeat the steps until you have enough labels for the shee
RobDraw
Are you through yet?
Rob
