Sheet index with visual dots - included in set
Is there a way to show an index that will reflect a sheet parameter "included in set"?
We do work for the corps (all Revit) and they require that the master index show two columns left of the sheet number.  In each column are dots which denote that each sheet is either "included in set" or in the column "not included in set".  A the end of the project we export our Revit sheets to .DGN per final submittal requirements. Up to now we do this index in Microstation, but it would be a huge time saver to be able to create it in Revit.
Thank you.
ryan.duell
Yes you should be able to do this with a calculated value column and a Yes / No parameter in the schedule replacing with a symbol.  Similar process at this post:
http://revitclinic.typepad.com/my_weblog/2010/04/modifying-a-yesno-parameter-appearance-in-schedules...
Substitute Yes or No with the Windows symbol you wish.
Another thread:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=24102
Ryan Duell
There's another simple way to add this by changing the font.
https://www.youtube.com/watch?v=hK31uoZNq24
