Visibility of cut lines in different views
In the constructor course many cuts are required. How about a switch "only in this view visible" when setting the cut? - Otherwise it`s necessary to correct or hide each cut line in all views before printing the documents.
alan.quinn
Thanks for posting, but I'm not sure what you mean by "constructor course". Can you add additional information or perhaps add a few screen shots. Thank you.
Yes, no problem: I mean the process of creating a Revit Model of a great and complex Building.
alan.quinn
I'm not aware of any automated way in Revit, however, I'm guessing that something is possible via the API. Here's a link to the Autodesk Developer Network.
In the project I find that creating View Templates speed up cleaning up views.
I hope this helps and thanks for posting.
I think, that afterwards there is no possibility to say only cut line A-A, cut line B-B and cut line C-C should be visibel. All other created cut lines should be automatically invisibel in all views. I`m shure, that doesn`t work via controlling the view templates. -> Therfore it would be better, to integrate a button "Only visible in this view" on creating process of a cut line. In other views, this kind of cut line will then automatically hid/invisible.
alan.quinn
Currently if any part of a section is in a view it will appear. You can turn off/hide in any number of ways. I like your idea of having a button, perhaps development will add something like this is a future release. If you are all set please mark this one as Accepted. Thanks again for posting.
