Hello L&G again,
I was thinking about doing the drawing issue sheet for a project.
I am trying to create a parameter of the drawing number to go into one column on the sheet list instead of project number/organization name/project volume etc
See attached image 1 (drawing no) from image 2 (drawing no 2)
Is there way to do that? I don't thinks on my ends
Solved by andr3sant0s. Go to Solution.
The project number/organization name/project volume are all distinct fields, you can add them or remove them from the sheet list. You can add fields from Sheets or from Project Information.
You can also combine fields to only one column.
The Number field is a parameter created for sheets.
Hope it helps!
Glad I could help!
Can I ask for you to accept my post as a solution?
Thanks!
