Shared the modifications with others
3 REPLIES 3
mairh_tsek
177 Views, 3 Replies
Hello all,
I would like to send the modifications that I do in Revit in the architects as an Image in order to see exactly what I changed. Until now I make the screenshots.
Any other quicklier way to do this?
Thank you in advannce!
3 REPLIES 3
you can right click om the view in Project Browser and save to project as image
make sure you set zoom to and up the image quality
AJ.
@Alan.johnson1970  ,
Thank you for your answer. I want to send the image in the architects, so saving them in the revit model it is not so convenient.
Autodesk has specific tools for this purpose:
  • you can use BIM 360 Docs or previous BIM 360 Team
  • or you can use the free aplication: Autodesk Viewer
You can share your Revit work with right of access option activated.....
Autodesk Viewer interface screenshot where you can see that you can choose what to share and with whom you share :
Constantin Stroescu
Forma Design Contest
Technology Administrators
