Shared parameter in title block
i am trying to give get a shared parameter on a dimension in a title block. I figured out that it can be done with a label, but obviously not with dimensions 😞
I've a revison scedule, so when it grows, my title blocks above it has to move with it, so now i am doing it manualy..
any ideas are welcome!!
Mirko.Jurcevic
I had the same problem.
I solved it by making revisions table upside down, meaning, headers of the table are at the bottom, revisions are added from bottom up - automatically.
Look at the image below:
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Hi Mirko,
done the same, but above the revision scedule there is more! See image. So if there would be a shared parameter for the seq revisions, i could make the generic annotations above the revision scedule parametric
Mirko.Jurcevic
I'm not by my computer so i am sorry uf i got it wrong.
I understood that you are trying to move upper table according the number in your revisions table. It is possible to move the table but not automatically, I am under the impression that you've got it by yourself. I would do it with type parameter since Revit cannot use number of rows in the revisions table.
Mirko Jurčević, dipl.ing.građ.
Poslano preko Samsung Mobile uređaja
Mirko Jurcevic
