Shared Family In Array Misbehaving
Mark.Ackerley
Message 1 of 15
Mark.Ackerley
Hi All,
Any assistance appreciated!
Please see attached Revit 2019.2.2 file.
I have a complex family for a pre-fab balcony... It contains nested shared families so I can tag them.
The nested shared families have instance parameters so I can use them in formulas in my array.
When I load the host family in, I am getting unexpected behaviour...
I have stripped the host family down to just the decking to illustrate the problem...
Both family types in the illustration below have been told to be the same width, but the lower one isn't responding correctly:
Incidentally, I have made the balcony a 'column' family category so that it will be room bounding.
As I understand it, my families are all built in a robust manner, I would appreciate any thoughts or comments which might help.
Mark
Replies (14)
Message 2 of 15
MostafaElashmawy
You was connecting the width of the nested family to a parameter called Decking Width while it should be connected to the parameter called BalconyAnnotation 2020-01-10 132937.png width.
Check below and attached.
Mostafa Elashmawy
Message 3 of 15
Mark.Ackerley
Thanks for the response...
You are correct that reasigning the parameter to a new value does 'reset' the values... Thank you I will use this for now, but I would also like to understand why that parameter broke...
The parameter Decking Width is related by a formula to Balcony Width...
This is because the Decking Width will be different to the Balcony Width.
Could you explain why you think using a different parameter would create the inconsistent behaviour seen in the image? Both of the types are linked to Decking Width of the same value, but the lower type is not responding to the value correctly...
Here is a gif which shows the inconsistant behaviour... You can see the lower Type does not respond to the change in parameter value...
Thanks again,
Mark
Message 4 of 15
MostafaElashmawy
The parameters of the board seems connected to wrong parameters.
The depth is connected to depth while the width is connected to board width.
Mostafa Elashmawy
Message 5 of 15
MostafaElashmawy
Also the parameters of width and depth of this board family are instance parameters while you connected them to type parameters.
I think that's the main problem.
Mostafa Elashmawy
Message 6 of 15
Mark.Ackerley
"The depth is connected to depth while the width is connected to board width"
Please clarify why you think this would be a problem?
I just tried this solution in the original family, it didn't work... But deleting the formula, accepting it, then rewriting it again did work.
I think that the Type and Instance issue is the thing...
As you will be aware, it is necessary to use an Instance parameter in order to have a shared family parameter be used in a formula in the host issue.
My suspicion is that Revit has got confused when trying to resolve these.
Thank you again,
Mark
Message 7 of 15
RDAOU
 In your posted Revit model it does work sometimes and sometimes not...that has nothing to do with instance and type parameters... It is breaking because you have issues with the way you have constrained the seed family (single board) in the first array family you did.
To a certain extent it will work as is but it will at some point snap/break unpredictably.
Message 8 of 15
Mark.Ackerley
That's interesting, thanks for the response...
Could you elaborate?
Could you also clarify why it works on some types and not others, both of which have the same value?
Cheers,
Mark
Message 9 of 15
RDAOU
  • The seed family (single plank) is ok as is
  • the Balconyfloor_DeckingBoardArray
    • When you insert the plank...lock its width using the shape handles - drag and lock to the reference plane driven by the width parameter (do not use associated parameters)
    • additionally, the array is locked to the start plane but its end is floating. you need to add a ref plane and set the depth...then lock the end of the array to that plane
    • the 10mm offset between the planks if it is always 10 (set its value in the formula to grey the value out)
  • load into the balconytest family...lock to the center planes and associate parameters
Message 10 of 15
Mark.Ackerley
Thanks for the suggestions....
"When you insert the plank...lock its width using the shape handles - drag and lock to the reference plane driven by the width parameter (do not use associated parameters)"
Am I misinterpreting?  Revit doesn't allow it?
Could you post your functioning file?
Cheers,
Mark
Message 11 of 15
RDAOU
Sorry I was out on a meeting... see the attached.
  • slight edit to the above (I kept the array "append to end" noticed you want to keep the offset between planks constant) - the other method of locking beginning and end of the array would resize the gap between planks
EDIT: sorry just noticed this is v.2020 I will redo with a screencast
Message 12 of 15
RDAOU
Just noticed your gif...you do not have shape handles because you have associated the instance parameters of the plank to those in the Array family... unassociate the plank's depth and the width IP to see the handles
After you lock the handles ...lock the middle ref plane then then associate whichever parameters you still need
Message 13 of 15
Mark.Ackerley
Thanks for the follow up.
For me, that only works if I subsequently go back into the instance and reapply the instance parameters to the plank, otherwise the width does not update and I get a constraints error...
Am I doing something wrong?
Cheers,
Mark
Message 14 of 15
RDAOU
@Mark.Ackerley
It must be something not constrained properly. Here is the screencast for the full process. Sorry I didn't post it as I thought you have solved your issue and moved on.
Message 15 of 15
Mark.Ackerley
Thanks, no that's fine, I have double constrained and it's working as expected.
Thank you again, hopefully that won't break again!
Cheers,
Mark
