Good morning. How can I make room tags visible in a Revit model please? Thank you ;-).
Happy birthday to everyone.
Pedro
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
Gelöst von GoldenGateNetwork. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Prepare a view in the linked model tha shows the room tags. Then in the host file while linking the model.
VG>> revit links
Make the visibility graphics for your link by linked biew and select the prepared view.
Mostafa Elashmawy
Thank you very much. Could you please show me by screen shoots, step by step? I was trying but I did not understand, sorry and thank you
You don't understand the screenshot I posted?
Only one step before that one I showed above.
I prepared this view in the file that will be linked and saved it.
then I linked the file to another host file.
In the host file I opened VG and did as below:
after applying, below is the result.
Mostafa Elashmawy
this is what I am getting:
Highlight the first row and press the By Host View Button to open the dialog box I showed in my first post.
T H A N K Y O U !!!! ![]()
T H A N K Y O U VERY MUCH !!!! ![]()
@GoldenGateNetwork, just in case you're still awarding Solution Credits for "thank you" posts...
Solution credits? what is that?
Good morning. I am having the same issue, I learned how to fix it but the dialogue box is grey out, could you please advice?
thank yo
In this view it is controlled by your view template, you can set it to <none> or uncheck revit links within the view template.
... on how to adjust view templates
... View templates in general
