Could anyone share a small (6x10m) technical building Revit assembly(?), that I can import in Inventor and see the capabilities of Revit/Inventor compatibility....
We use solely Inventor, but might be interested in using Revit alongside.
Many Thanks, Johan
Solved by RSomppi. Go to Solution.
Solved by aRcHiTeCt.JM. Go to Solution.
Have you looked at the samples that come with Revit?
We don't have Revit yet, so that's why I ask for a sample model from people that have Revit.
off course
here are some technical samples
(if need more just ask)
** UPDATED to REVIT 2023 Version
** medical updated to metric version
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thank you. importing these models state that it is from an earlier version and take extra time to translate. Are there any 2023 models around?
Download the trial. You can get all of the content with it.
It might be possible to download the content without the program also.
