Shaft or openings
6 REPLIES 6
mairh_tsek
700 Views, 6 Replies
Shaft or openings
Hello all,
I have a project with multiples levels. I want to create openings  which are  repeated to all the floors. Does it  better to do it with the shaft tool or with additional loops in the floor sketch mode in order to create the openings?
Thank you in adcance!
6 REPLIES 6
ennujozlagam
in reply to: mairh_tsek
use shaft. thanks
mairh_tsek
in reply to: ennujozlagam
@ennujozlagam ,
Thank you but why?
ennujozlagam
It's easy to adjust if there any changes of length and width of opening rather than adjusting every floor opening. Thanks
If dimensions changes in your openings you have to repeat it on all floors, while in shaft its don't once, it will reflect until its reach throughout the building.
Another Positive point in shafts favor is it will not create issues with the wall. For example, if your floor is bound and you change openings you will get many errors regarding some objected are not joined and stuff.
Frame it.  Don't fake it.  Shafts don't cut away everything.  Got joists?
Dude, I'm not the OP here.
