Revit cannot import the file Problem!!!!!
QQ截图20190705230707.pngQQ截图20190705230733.pngQQ截图20190705230800.pngQQ截图20190705230742.pngTry to import a rhino file to Revit using, but it shows Revit cannot import the file. Why???????
You can export from Rhino to skp , open skp with Autocad (via "Import SKP" add-in), save as dwg and insert the dwg into Revit.
