Doors and Windows are not transparent
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
3060 Aufrufe, 11 Antworten
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
I think what's happening, is that Phases are overlapping. Set Phase Filter to Show Complete.
If that's not it, go to family and select the Opening Cut and look on the Option Bar. You'll see two check boxes. Check them both.
...are you sure you have a transparent material (e.g. "glass") assigned to the glazing geometry???
Nachricht 3 von 12
als Antwort auf: barthbradley
I tried it but it didn't work. Can you please tell me how can I select opening cut in modify command because there is only option is showing " load family".
Nachricht 4 von 12
1. Open Family.
2. In 3D View. Window-Select everything.
3. Click on "Filter" button on the Contextual tab.
4. Uncheck every box except "Opening Cut" and press "OK"
5. Check boxes for Transparent in 3D and Elevation should now be shown on Options Bar.
NOTE: If you don't see "Opening Cut" listed under "Filters" in Step 4, then your Window is probably using a Void Extrusion Cut.  So, this workflow wouldn't apply.  Question: Do the Windows cut the Project Walls?  Isolate Wall in Project View and see if they show an opening cut for Windows.
Nachricht 5 von 12
Are you sure that this isn't about Phases or Material, as I mentioned above?
Post your file.
Nachricht 6 von 12
Yes I have checked my phases and material. Everything is fine. I also checked family steps which you mentioned in last reply. Now windows and doors have become transparent in "shaded view" but still they are non-transparent in "realistic view".
Nachricht 7 von 12
I have attached file here below.
Nachricht 8 von 12
I have attached file here.
Nachricht 9 von 12
Windows are transparent when I open the file at my end?
Try deleting your 3D View and recreating another {3D} view.  If that doesn't solve, post a screenshot of your "Glass" Material's "Graphics" and "Appearance" tabs .
...if you mean the Windows are not transparent in Elevation Views; that's how it is in Revit.  Windows are NOT transparent in Elevations.  To make them "look" transparent in Elevation, turn off the "Glass" Subcategory under "Windows" Category in the View's Visibility/Graphics Overrides.
...could also be hardware related.  Your Graphics Driver.
Nachricht 10 von 12
Nachricht 11 von 12
Yes, your Material has NO transparency.  Check "Transparency" or use another Material/Asset that is transparent.
Nachricht 12 von 12
Yes it works. Thank you so much for your support. I really appreciate it.
