Firstly, i have an issue with creating shadow diagrams. I copy the site plan several times and use `Still` in the light settings to select the day and time i want the shadow diagrams to be. This works without an issue. However, when i go to my next copied site plan and change the shadow settings, the other site plans shadows change too. Therefore i cant have individual site plans on sheets showing different shadows. Why is that?
Also, im new to rendering and when i click the render button i get something like the attached image. Can someone help with some basic settings to achieve a better rendering? Im obviously missing some major commands etc.
Tim.
its ok thanks. Figured it out.
The key thing is to set up each shadow and have it correspond to each sheet. I wasn't setting up each shadow in the shadow settings, so it was changing every site plan.
