Revit 2020 "An unrecoverable error has occurred." HELP please
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
S.Reise
3818 Aufrufe, 8 Antworten
I´m trying to use Revit and every time I try to open a family either by double clicking it or opening it with another project open it says "An unrecoverable error has occurred. The program will now be terminated."
This happens also if I have an open project and want to open another one in the same "Revit", if I open each file by itself it works, its just whenever I want a second project to open...
I´ve tried uninstalling Revit with the uninstaller tool, restarting computer and installing again and it keeps happening, also Reinstalling from the Microsoft uninstall and nothing seems to work...
The screenshot attached is just to show that I uninstalled Revit, restarted and installed again, the double click on the table from the sample project and that happens, every single time.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: S.Reise
Just one family or any RFA?
Nachricht 3 von 9
S.Reise
als Antwort auf: barthbradley
any family, or even opening a second project with a project or family already open crashes it
Nachricht 4 von 9
Is Revit the only program crashing?
Nachricht 5 von 9
S.Reise
Yes, I´ve opened several projects in autocad with no problem
Nachricht 6 von 9
Nachricht 7 von 9
S.Reise
Thanks for the help! I´m attaching the log and .txt journal of my last attempt
What I did: Open the sample project, go to 3d view, double click on table, crash...
Nachricht 8 von 9
S.Reise
Thanks barthbradley!! it seems is a plug in, now ill start adding them one by one and testing to see if I find wich one is causing the problem...
Thanks a lot!
Nachricht 9 von 9
S.Reise
Just if anyone has the same issue, delete the "smart revit dock" plugin from C:\ProgramData\Autodesk\Revit\Addins\[Version].
It worked for me at least
