Shadow bug in Plans
Shadow bug in Plans
mahyarSOORANI
Shadow bug in Plans
mahyarSOORANI
when i activate the shadows i see the shadows of the door frames which i dont must see them
i attached the v24. file too
how can i remove the ? i changed the view range and sun setting but it wasn't fixed
jay_colcombe
I would say this is a Bug as it appears to work for all other Graphic Display Option with Textures being fine and the closest comparison
Jay Colcombe
Autodesk Certified Instructor
vitorbortoncello
The shadow is being cast because the view range of the floor plan cuts through the doors. You can try adjusting your sun settings so that the shadows align at a 45-degree angle. This way, the door frames won't be visible in the shadow.
Did you like the post? Don't forget to Like and mark Accept as Solution.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
TripleM-Dev.net
Hi @mahyarSOORANI,
It's not a bug, seems to be the stock door family?
They have filled regions in them as frame, that's what you're seeing. The filled regions are in all three detail levels so you can't get rid of them without editing the family. (turning the detail item category off in the view doesn't solve it either)
Edit the Door family and edit the filled region detail levels so that there's one level that doesn't have any filled regions and set you're floorplan to that level.
Also the door leaf isn't throwing a shadow (and floor section for that!), because the door geometry is turned off in 2D floorplan view.
Another option (without editing the family) is to use a 3D view and orient it to the floorplan, but you won't see any of the 2D elements.
- Michel
mahyarSOORANI
Thanks . I Understood but the regens must be remove that the Appearance will be ugly . i Think i should use the other Family door.
Anyway, thanks
