Revision by sheet not working as expected
gideon.botesB4GMB
gideon.botesB4GMB
Good day,
Using Revit 2023.
I have set my revision sequence for a file to be 'by sheet', however it appears to still be 'by project'.
If I, for example, want to add a new sheet in the file - if I then go to the Revision dialog, or try to cloud, the system still uses revisions from the whole project. I cannot add say, a separate 'revision 1' for different sheets created on different dates.
Help is appreciated!
You misunderstood.  By project or By sheet is for numbering.  By project means the number of a revision is the same on every sheet. By sheet means the number of a revision can be different on different sheets,  depends on the sequence of the revision on sheets.
