Shade overhang and shade fins
arghavan.A
Message 1 of 17
arghavan.A
Hello!
What is the best way to draw Shade overhang and shade fins using Revit 2018?
I want to draw the shadings in the picture below:window shading.JPG
Arghavan
Accepted solutions (4)
Replies (16)
Message 2 of 17
ennujozlagam
@arghavan.A hello, either you create model -inplace sweep in the project itself or make a family and load into your project. thanks
Message 3 of 17
arghavan.A
@ennujozlagam thanks! Can you please tell me how should I create a model inplace sweep? I don't want to create a new family.
Message 4 of 17
ennujozlagam
@arghavan.A hello, i don't have my own but you can refer to youtube tutorials how to create sweep here are some samples. LINK / LINK. thanks
Message 5 of 17
arghavan.A
@ennujozlagam Thanks! I found out how to do it eventually!
Follow up question
I want to export this model as IFC, how should I assign the IfcShading to this object?
Message 6 of 17
ennujozlagam
hello, just go to FILE export > ifc. thanks
what do you mean? can you please explain more. thanks
you can use insert > link IFC to your revit project file.
Message 7 of 17
arghavan.A
What I mean is that this mass object is not by default a shading, so Revit would not assign IfcShadingDevice to it by default. For example, as a contrast to this case, when you create a wall, Revit is intelligent enough to assign an IfcWall to it.
My question is, how can I assign any desired Ifc to a mass object?
Message 8 of 17
ennujozlagam
@arghavan.A hello, i saw your question in a previous thread HERE did you get an anwer? i'm not sure about this. thanks
Message 9 of 17
arghavan.A
Hi!
No, I still have not found my answer yet.
Message 10 of 17
FAIR59
you assign a subcategory to the mass-forms.
and then you can define in the Export / Options /  IFC-Options how the mass gets exported
Message 11 of 17
arghavan.A
Thanks @FAIR59!
But did you add IfcShading yourself?
Message 12 of 17
FAIR59
yes, in the options you can type anything you like. You mentioned ifcShading, so I typed that, I didn't check if its a valid ifc entry
Message 13 of 17
arghavan.A
@FAIR59 Hello again!
I tried to add "My Shading" to subcategory as you said, but it does not apply! When I write it and hit the apply button, then subcategory turns into <None> again. Any suggestion why this happens?
Arghavan
Message 14 of 17
arghavan.A
SHADING.JPGThis is a picture of what I mean. Please correct me if I miss understood what you said earlier.
Message 15 of 17
FAIR59
you have to define the subcategory before you can apply it.
To make a subcategory -  [Manage][Object Styles] select the category (Mass or Generic Models) and make a new Subcategory.
Message 16 of 17
arghavan.A
Hi again!
I tried to delete the subcategory that I created, and it was deleted in the "Object Styles". However it still exists in the list of subcategories in the the IFC Options! Is there any solution to remove it altogether from the IFC Options as well?
Thanks!
Arghavan
Message 17 of 17
FAIR59
There is no solution using Revit. But the IFC-options file is a text-file, perfectly readable. So find the file and delete the line where the subcategory is defined.
I haven't tried it, so make a backup copy first in case of disaster
