- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The option to set the wall "height" or "depth" is not adjustable and is locked in the depth setting. This is not allowing me to use the wall tool effectively.
I found a workaround by going into 3D and setting the level to the main level, drawing a wall, and slowly changing the settings to get the basement walls from floor to ceiling. However, the next time I use the wall tool or create similar, it's reset to errors again and tries to draw from the basement floor to -12'-0". Why??
Is there a way to change this always to be set to height? Like most designers, I do not draw top down but bottom up.
