Firstly wanted to try split my floor with using precast function "split", to make hollowcore concrete floor. And it says: Revit structural precast content is missing. Please select the content folder appropriate for the current language. And this problem is on everyting in precast tab.s I tried to also download other libraries and check it for acceptable content. Maybe someone can help to solve this problem?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Yep, i found it, but i have 2024 revit, so this method is invalid for me.
Do you have a C:\ProgramData\Autodesk\RVT 2024\Libraries\English\US\Structural Precast Folder?
in 2024 it is now located under the English > US file location which was not the case previously
@edgarsceplis09: this is what you should see - a link that you can press to automatically load content:
My revit after update give me link to download content. So thanks for help.
It pre-installed but in the U.S. Metric Library location!
If you mean Precast families you need to install the Content from your Autodesk Account or from the Insert Tab > Load from Library > Load Family and search for Precast Content
are you using Revit LT?
have a look here this will walk you through it
https://forums.autodesk.com/t5/revit-structure-forum/precast-content-is-missing/td-p/12703384
Are you trying to use the Precast Tab?
or
Use a Precast Column or Beam?
it’s really not clear!
I am trying to use the precast tab, however, when selecting a button it asks to browse for content, which l do not have even after installing library content.
Precast tab. Asks to browse to locate content, which l do not have, even after library installation.
Nothing here?
